Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Killing time. Well, almost. pic's
Old Mar 16, 2010 | 07:44 PM
allngn_c5's Avatar
Originally Posted by sciff5
Btw I dont know how stable c5s are at extreme speed I'm sure they're fine at say 180. Any C5s gone 220 before that you could use as a point of reference?
My FRC was at about 204, 205 when the shift light came on in 5th gear and I let off. Car is on coilovers, lowered and was as stable as could be. I even carried the slight curve at the end of the long *** straight at 175 and the car didn't tilt at all. I had to hold on tight because the car was flat and the G forces were definately being exherted on me !! Can't wait to do it again.
As always good luck J Dizzle !!!
Old Mar 16, 2010 | 09:48 PM
JoeyGC5's Avatar
Originally Posted by BlownVette 2001
^ Just that it was somewhat interesting that a vette with less than 500 rwhp almost hit 180 in the mile.
I've done a mile run or so, but not legally in this coming up I40 in Tennessee.
My 3622lb Vette (with me in it) on 91 oct pump gas and just like I drive it on the street went 178mph into a 20mph headwind (512rwhp). With the 750+ hp range that V-series is talking about should be good for the 200stab. Hell I'm going for 200 with tha much power in an 8point caged, 10lb fire system, ac equiped, parachute equiped street car that my girlfriend drives also. Its all do able and I like the routes that are being taken.
My Motive 3.42 geared rear is a bitch at the drag strip. But I can 1/4 mile, standing mile, and get groceries with the car all while trying new things out.
Old Mar 16, 2010 | 09:50 PM
JoeyGC5's Avatar
BTW, is your car tubbed ? I'm trying to figure out if 18x12 rims will rub on the upper "A" arms if I go airborne.
I plan on using some of those new LG coil overs (red adjustable) ones since I'm throwing in the C6 Z06 differential and rear left over from old blue. The coil overs will help limit my droop.
Also picked me up some C6 Z06 brakes for a little bling.
Just trying to figure out the whole rear rim thing so I can order me up some rims and tub the car as Spring is coming and I can work outside my garage a bit.
I would like to get all the mechanicals done and have the body & interior done over the winter.
My car is tubbed 2.75" and the 18 by 12 CCW's will contact the upper A-arm when the car is in the air, but I've never seen grinding marks in the time or two I've exceeeded speed limits on hilly roads.
Old Mar 17, 2010 | 04:54 PM
V-seriesTech's Avatar
787 is on the stoock bottem end, untouched AFR 205's, and a fast 90...not to mention, a fuel system that was maxxxxxed out at 5000rpms and 700rwhp.
Everything is different, except for the turbos, which never saw more then 11.5psi. They'll be closer to 20 this time around. New intake, new heads, new block, new fuel system-completely new and ready for 2xxx hp. Nothing is the same.
Looking for 1000-1300rwhp. No bullshit.
Old Mar 17, 2010 | 04:56 PM
..check this out. This guy, very cool dude, I met him at the one mile this past weekend.
870rwhp....
http://jlturbo.com/vids/TOPGUNRUNMar...nFinal-web.wmv
Old Mar 17, 2010 | 05:53 PM
JoeyGC5's Avatar
I was replying to Blown Vette and our different approachs....???????
Old Mar 18, 2010 | 04:51 PM
Guess I misread that part with my name in it.
Calm down. Take some insulin.
Old Mar 18, 2010 | 07:41 PM
JoeyGC5's Avatar
I'm taking everything with a grain of Chicken mushroom risotto at the moment man
Old Mar 19, 2010 | 05:31 PM
puff puff give...
Old Mar 22, 2010 | 07:15 PM
BlownVette 2001's Avatar
Thanks. I'm going with the LPE Tub kit to keep it clean. Hoping the coil overs will keep suspension droop to a minimum if I go airborne
Old Mar 22, 2010 | 07:29 PM
I'm just real theoritical. V-Tech has a hell of car and I could see him pulling off 200 + mph in the mile.
I see that some guys with a lot more power do really poor times due to traction or other handling problems, to guys with way less power.
It seems that you need to put together a great combo of things when building a car for a top speed run.
- Traction
- Handling
- Brakes
- Power
- Gearing
Boost by gear would greatly aide traction and help improve top speed and time.
Wish I lived near one of these mile events as it would be a good place to go and get some real world experience.
Old Mar 22, 2010 | 07:36 PM
  #32
Ahh..had a long response but...freaking computer locked up.
Whatever.
180mph tony,...is no where near 200. I understand ALOT of cars coupld hit 180-190etc ..it's that 199.99+++ mph thats the bitch.
My comment about the corvette forum,..it stands in my opinion. For example, everyone on there, is a rocket scientist. Everyone knows everything because the internet told them so. Most of them pay to have someone mod there car,...to that, what insight could they provide someone like myself, or you for that matter? That place, as I said, has very CRAFTY(as in smart) people... the rest, either are cool, and admit they're lack of knowledge, or they are dipshits,...and act like they know everything. Thats that forum,..imo.
My car is mini tub'd. It will fit 12+ wheels. It WILL RUB THE INNER FRAMERAIL and possibly the A arm WITHOUT coilovers. With coilovers, you will never have a problem.
Don't ya hate it when you type your heart out and get ready to post your message and the dang computer has a brain fart.
Thanks for the info on the tub.
As for the CF, it's a good place for us waxers
Can't wait to see your finished product. Going to go to a couple car shows and see if there is any new FI systems, etc ... coming to market.
Oh well, back to work for me.
Old Mar 22, 2010 | 09:57 PM
  #33
- Traction
- Handling
- Brakes
- Power
- Gearing
Your very right,...combo is everything. Each thing, will compliment the other. We'll see what happens with traction...I don't thing i'll have a problem mid 3rd and higher...I hope. Thats with RA1's more then likely. We'll see though. In this car, it's always a learning experience but,..on paper it looks good.
Again,..we'll see.
Highly recommend taking a trip to texas/miami or maxton one day, and watch the event,.. in some way, see if you could participate. I promise, you'd probably be very much hooked.
Yeah, computers always get the best of me, more so lately. The CF is a great place for info......alot of people... alot of problems/questions/insight. Dechipher through it,..some of it's very good.
Looking forward to the runing project,...I don't know if I will have it "finished" anytime soon,...I foresee another 5-10 years of modding this beotch.... as I don't have tons of cash,... don't have tons of time but,.. this car isn't going anywhere,...at the moment, neither am I,... might as well make a long term project out of it. Step by step, one day at a time.
Just had some strange...now I...I think I will pass out.
peace.
Old Mar 23, 2010 | 04:19 AM
  #34
Again,..we'll see.
Highly recommend taking a trip to texas/miami or maxton one day, and watch the event,.. in some way, see if you could participate. I promise, you'd probably be very much hooked..
The Toyo RA1's are very nice tires. My buddy who road races runs 275 & 335 /18 combo and his car really sticks in the turns.
Would love to get out there one day and watch/participate but my job is so unpredictable. One day I'm here the next day I'm in NY, Texas, Florida, etc ...
I would need to plan way in advance if I ever wanted to go.
I'm slowly working on my SW Z06 that I bought. Been picking up parts as time and space allows. I got so many parts right now from all of my other car projects that I have no space left to put anything until I can sell some of the stuff off.
Hope to clear out enough of the stuff over the next several months so that I get the car back into the garage by winter. Right now I have (3) motors a couple trannys, differential, exhaust, body kit, C5 chassis, and a whole host of other parts to sell.
peace.
Old Mar 23, 2010 | 02:15 PM
  #35
PA Z06's Avatar
Dam J do you ever stop
Old Mar 23, 2010 | 03:29 PM
  #36
wilson34's Avatar
When you modified your fuel hat, is the ecs spacer used as the return or the fuel feed?
Thats on the drivers side too right?
Anyways, goodluck at the mile and your car will be eatin
Old Mar 23, 2010 | 03:32 PM
  #37
wilson34's Avatar
Tony, do you have any C6Z06 tranny or diff stuff for sale, I'm in PA and could pick that **** up
Old Mar 25, 2010 | 05:43 PM
  #38
I feel you. I need to sell a bunch of random stuff as well mang.
I honestly wish I could. I'm tired bro.
yes sir, drivers side hat.
That IS used for my return, since it's a -8 line.
Thanks man,...hope it does well.
I'd be interested as well possibly if you have something and wilson doesn't want it.
Old Mar 25, 2010 | 06:05 PM
  #39
I've got a 3rib DTE stage 5 differential with 20 miles for sale.
I'm using the the C6 Z06 differential and tranny for the SW Z06 along with the LS3 motor I bought.
Old Mar 27, 2010 | 07:33 PM
  #40
wilson34's Avatar
Im going to keep looking til I stumble upon C6z06 rear setup
