Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Where to get engine electrical connectors?
Old Jul 5, 2010 | 08:20 AM
02402RAMAIR's Avatar
Default Where to get engine electrical connectors?
I am in need of some connectors for my C5. I am looking for the C5 throttle body 2 wire connector. The TPS connector. The Injector connectors. The coolant temp, map and IAT connectors.
I have a Harrop intake that I need to wire up. I also have a Fast intake. I am wanting to put some connectors by the battery so I can unplug one intake wiring harness and plug up the other if I decide to switch intakes.
The connectors would need to be a minimum of 8 pin. I would have to use several to get the injectors, TPS, ETC, MAP, and IAT.
Part numbers for the factory connectors would be great or a link to who has them. I have found the Injectors connectors but not the others.
Thanks for any help
kris
Old Jul 5, 2010 | 08:38 AM
Bluewire's Avatar
Here is one place you can go, I think they used to be a sponsor.
http://www.casperselectronics.com/st...x.php?cPath=53
Im sure you can find other places as well.
