Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C6 overheating
Old Sep 24, 2010 | 03:28 PM
Dark SS's Avatar
Default C6 overheating
My sister has an 07 vette and the fans don't turn on. If you let the car sit it will over heat and shut down the A/C. This happened once before and she took it in under warranty and the dealer said they replaced the fan relay. Now the car is out of warranty and I want to try and replace the part myself. The car sits a lot and goes though batteries because she never plugs the damn thing in to the tender. Any ideas?
Old Sep 24, 2010 | 05:33 PM
clint195's Avatar
I am going to guess it is the cooling fan plug. I believe these were know to melt and cause the fan not to work. It should be an easy fix if that is the case. I thought that it usually happened when people altered the tune but it would be worth checking.
Old Sep 24, 2010 | 05:53 PM
clint195's Avatar
Here read this and check out post 16 for a pic of what i was talking about.
http://forums.corvetteforum.com/c6-t...d-working.html
Old Sep 26, 2010 | 02:32 PM
Dark SS's Avatar
Thanks, I'll check that out.
Old Sep 26, 2010 | 04:52 PM
Dark SS's Avatar
So no burned connector. Any way the module could be bad?
