Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Evans Water pump GP
Old Mar 3, 2004 | 06:05 PM
Nasty N8's Avatar
Default Evans Water pump GP
We have made the GP prices good. If you are interested they are now shipping.
Evans Cooling Systems Inc has just released a new highflow LS1-6 water pump. The billet coolant pump and pulley flows over 20% more than stock and changes the cooling pattern for a more even cooling. The pump increases cooling efficiency in modified LS1 Corvettes, Camano’s and LS1 based motors. Evans has changed the design of the OEM pump casting and includes a billet pulley hub and heavy duty 3/4" shat bearing assembly. It also includes a 3.8" OD 8 vane scrolled impeller to reduce parasitic horsepower loss at high RPM. A new serpentine belt is required.
pics
Evans complete new water pump with billet pulley $469.95 for Corvettes
Evans complete new water pump with billet pulley $469.95 for F-Bodies
Brand new casting no core retail $469.99 GP $395.00 NO core required
Used casting remachined retail $399.99 GP $340.00 +$125 core charge
Add $125 for ceramic thermal coating-for extra heat dissipation and a little bling
Evans super flow 160* T-Stat $49.95 reqiered with purchase stock does not flow enough
Goodyear serpentine belt $49.95
Evans NPG coolant $22.50 a gallon
Evans NPG+ coolant $22.50 a gallon
Also Evans new NPG R race coolant in stock $19.50 a gallon
Or buy by the case(4) and save
__________________
