swaped over to mn12 car is slower?!
The LS6 made power higher in the RPM range than the LS1. In addition, to make up for the shorter gearing, the LS6 pulls 500 RPM more than the LS1. Seems now you should change over to the LS6 heads, intake and get either an LS6 cam or a 224R cam. Set your rev limiter to 6500 and you should have a 99 Z51 w/ an LS6 drivetrain. Personally, I would have stayed with the MN6 with a stock motor. But you're better off at least getting an LS6 cam at this point.
BTW, if you car has 3.15 gearing, you had an auto originally. So your gearing is going to be completely different. The 4L60E ratios worked well with the 3.15s. But at this point, you're going backwards. You'd be best off upgrading to 3.42s.
But you are right Speedway White is the best. I love my SW Z06!!
I think Speedway White started in 01. (I could be wrong about that, though)
I'd LOVE to have either an FRC or another Z06 in white.
And I second that I am actually on the prowl for another vette and I have my eyes set on a 01 SW Z06.
Thought he had two cars there for a second. Last edited by OneBadZ0Sick; Aug 27, 2011 at 06:10 PM.
If you are going to do that sort of swap, put in a moderate cam and an affordable stage one head from a vendor. You'll make a lot more power and be a lot happier.
Quick spreadsheet I threw together to compare the two. It should be close but not 100% on the money.
Probably the best setup would be 1-4 (well 4 doesn't matter) from the MN6 + 5/6 from the MN12.
Also, keep in mind that with any cam-only setup, you're still going to have to pull the valve covers and replace the springs anyway. So add in the cost of springs. If you go with a LOT of lift, you'll have to fly-cut... So exactly how much power do you want to make without changing the heads?
What's easier and cheaper? LS6 kit. What's going to make more power? A big cam and headers. What's going to achieve his goals? Both. So why is this an argument?
Spacing of the mn12's 1-2 and 2-3 are similar to the mn6, but since 4th gear is 1:1 on both trannys, the mn12 has the big 3-4 spacing to make up for the numerically larger 1st ,2nd and 3rd gears.
