Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
headlights are grinding.. how can I fix this? please help
Old May 24, 2012 | 10:56 PM
rio95cobra's Avatar
Default headlights are grinding.. how can I fix this? please help
the pop up lights in my c5 go up and go down fast and smoothly.. except when I turn the headlights off and the lights go down, I continue to hear a loud grinding noise for around4-5 seconds.
do I need to replace the gears? or what can I do to make it stop?
Old May 25, 2012 | 12:01 AM
slammedc5's Avatar
Yeah, just did mine. Had the same issue as you. I upgraded to the brass gears.
Old May 25, 2012 | 05:58 AM
rio95cobra's Avatar
But the gears are obviously turning and working fine because the headlights still go up and down. Could it be something else?
Old May 25, 2012 | 01:11 PM
slammedc5's Avatar
There stripping when there making that noise, won't be long before they won't open or close. Your at the " your being warned" phase.
http://www.vetteweb.com/tech/vemp_04...p/viewall.html
Old Jun 7, 2012 | 04:38 AM
GTSC5R's Avatar
Gears are stripped, you can replace with brass gear and never have a problem. I went with the free route and spun the gear to an unused portion and never had any problems for years. I can't find the link for the how to, but you might want to check the corvette forum, this site is pretty lite on vette specific stuff.
Old Jun 7, 2012 | 04:39 PM
chuck01's Avatar
He is correct, just do a search on the corvette forum. You can buy a plastic gear and fix it on your own for less than $15 Bucks.....
Old Jun 7, 2012 | 05:08 PM
Silver408z's Avatar
Its your gears. I had same problem and thoughts when it happened to me. I replaced it and havent had the problem since
