Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
4l80e or t56??
Old Jan 26, 2013 | 11:14 AM
kimbofb97's Avatar
Default 4l80e or t56??
which tranny is better for 750rwhp in a c5 corvette? i appreciate you help!
Old Jan 26, 2013 | 12:49 PM
V-seriesTech's Avatar
Ah,.which is better for you? What are you doing with the vehicle? If someone like myself suggested, it would be a manual, all day. Made over 780 wheel, on a stock T56, in a daily driven application. Totally stock T56, other then shifter mods. A clutch would be your concern, that or the differentials.
Old Jan 26, 2013 | 04:45 PM
RonSSNova's Avatar
I don't think you can put a 4L80 in a C5.
Old Jan 26, 2013 | 06:26 PM
FRISKY's Avatar
Drag race or daily driver - auto. Everything else - stick.
Old Jan 26, 2013 | 06:43 PM
buddhaz06's Avatar
80 is a very expensive swap
Old Jan 27, 2013 | 11:05 AM
Blackpanther99's Avatar
80e for alot of racing, T-56 for just street driving or very little racing, but I believe 80e swap will be very expensivr on a C5
Old Jan 27, 2013 | 04:50 PM
MikeB52's Avatar
A friend of mine is currently building a N/A LT1 for around 650rwhp with a 200 shot and hes using a stock T56. seems to be more worried about the clutch, like V-seriesTech said.
Old Jan 28, 2013 | 11:20 AM
Yeah^ those T-56s can hold some good power before getting into the rebuild idea, replacing the clutch is the most worrying thing really.
Old Jan 28, 2013 | 02:16 PM
Silver408z's Avatar
If you pick t56 go with a t56 magnum or tr6060. They are stronger and hold power better. Think its the output shaft of the normal t56 is kind of weak and the magnum/tr6060 have bigger/stronger output shafts.
Old Jan 28, 2013 | 02:51 PM
Dark SS's Avatar
4L80 is the best street strip auto for a GM car period. It is a little expensive to get into a C5 or C6 if you have someone do it because there is a lot of trimming to get it to fit. I prefer and auto and if you have the money a 4L80 would get my vote. Bulletproof. However with 750 rwhp a built 4L60 will hold up and fit with no trans tunnel modification.
Old Feb 1, 2013 | 02:21 PM
Agreed^ a 4l60e can also hold good power on Vettes, but your best bet is a 80e.
