Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 Z06 Shifter question
Old May 17, 2013 | 06:20 AM
wooddaniel's Avatar
Default C5 Z06 Shifter question
I'm having trouble with my shifter on my C5. It is not wanting to go into second or 6th at times. I don't think it's an internal problem, I think it's something to do with the shifter because I didn't have this problem before the clutch install. The clutch works fine in all the other gears, good engagement and disengagement. I took the console apart and adjusted the shifter a little, and it made the issue a little better. I guess my question is, is there a way to "center" the shifter, like some sort of way to gage when it is factory center? Thanks in advance
