Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Z06 Rocker Arm Upgrade
Old Jan 18, 2014 | 08:05 PM
ajgreen40's Avatar
Default Z06 Rocker Arm Upgrade
Has anyone upgraded the rocker arms on an LS6 motor (2004 Z06)? If so what length pushrods did you use and how many HPs did you gain?
I purchased a set of CompCam Ultra Gold Rockers..
Old Jan 18, 2014 | 10:33 PM
yonerhottlt1's Avatar
Is your car already cammed?! The stock rockers work pretty well in these LS motors. Rule of thumb is to always measure as far as pushrod length goes...
Old Jan 18, 2014 | 10:47 PM
ajgreen40's Avatar
No it's not cammed. Intake has been replaced and it has a set of shorty headers.
Old Jan 21, 2014 | 02:18 PM
Ok, well in that case aftermarket rocker arms should be the least of your worries. Even if the motor is modified the stock rocker will be more than enough to suffice. The only time you should be worried about running an aftermarket rocker is if you're also running an aftermarket set of heads that do not accept the stock ones. Hope this helps.
Old Jan 21, 2014 | 04:21 PM
djfury05's Avatar
Consider returning the Comp Cams Ultra Gold's and doing the Comp Cams Trunion upgrade to the stock rockers instead. A lot cheaper and all that's needed with no chance of losing the needle bearings through the motor.
http://www.summitracing.com/parts/cca-13702-kit
Old Jan 28, 2014 | 01:58 PM
jp260z's Avatar
Default Trunion Upgrade
I agree. Money is better spent on the Comp Cams trunion upgrade.
Old Jan 28, 2014 | 07:06 PM
lilgbz28's Avatar
I have a big cammed 04 z with trunnion kit deff helps with it but if your stock cammed I wouldn't worry or mid cammed . Dosent hurt thou
Old Feb 11, 2014 | 11:24 AM
vettenuts's Avatar
In addition to pushrods, better add valve springs. Stock LS6 springs won't control those rockers at high RPM. This is very expensive for what at best will produce 5hp on the dyno.
