Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
2006 z06 common issues?
Old Feb 18, 2014 | 01:28 AM
Jadedbird's Avatar
Default 2006 z06 common issues?
so after selling my ws6, im in the market for a c6 z06.
I have heard many stories with the 06 and early 07 models having trouble within the heads in the ls7 engines. what procedure do most do in order to fix this issue? how can this be fixed? or do the entire heads need to be replaced?
EDIT: on corvette forums there is info on the rocker arms needing to be replaced in 07 models, but is there not some trouble with the valve guides as well?
I also read that an oil cooler would be a good investment as well?
car will be a DD for the majority of time, then as i get more money to invest, it will be seeing more track time and receive supporting mods.
any other common issues with the 06-08 z06? seems like every time i search, it brings up the common issues with the c5z..
Old Feb 18, 2014 | 10:05 PM
Silver408z's Avatar
If you can buy a 08, go with it. You get a tr6060 instead of a t56. Ls7 heads had issues with valve guides or something that caused them to drop valves. Not sure how common it really was or not.
Old Feb 19, 2014 | 12:31 PM
ysb02's Avatar
I think all years need to be checked out but go 08+ for the 6060 like silver said. The 06s had weak axles
Old Feb 19, 2014 | 08:29 PM
Jadedbird's Avatar
well is it possible to put a tr6060 in a 06 or 07 model? as for weak axels, i dont plan on running slicks so it shouldnt be terrible.
i realize that these are street cars and will need proper transformation in order to be functional track cars as well.
Old Feb 19, 2014 | 08:39 PM
Silver408z's Avatar
I know to convert a c5 to a tr6060 it runs about $6000 for parts. I am sure it would be cheaper but the I bet its still over $4000 is my guess.
Old Feb 19, 2014 | 09:11 PM
Jadedbird's Avatar
well i made a forum on corvetteforum.com
i found a velocity yellow 06 along with 4 others in my price range. i know the 06 have their troubles, but its not like i dont have plans to have everything built or replaced anyhow
Old Mar 4, 2014 | 07:06 AM
pontiac's Avatar
I think the best buy is in the 06-07 at the moment. you will take less of a loss, and its just as fast of a car.
is a TR6060 better transmission then a T56? yes, is it better buy any amount that's going to show its face? no. the T56 has been handling vetts vipers and cobras for years. there was just finally a few upgrades made. its nothing to shy away from..
all LS7s CAN have a valve guide problem, the forums blow the numbers way out of proportions. but wroth addressing if your modding for sure.
the 2007 was the year for the needle bearing issue. can check vin to see if its in the range, or trunnion upgrade.
Old Mar 5, 2014 | 12:14 AM
Jadedbird's Avatar
well i would love to get into a ls7 but friday im going to look at a ls3 vette for $20,900. 80,000 miles is a bit more than i was wanting but then again this is a very good price and i would feel less guilty about using it for a DD
Old Mar 6, 2014 | 05:23 AM
pontiac's Avatar
thats a great buy as well, you will enjoy it ALOT.. 99% of the time the Z potential is not used... brakes, handeing, power its there when you push it but lets face thats not all the time. the handeling most owners dont ever push the car to the edge.
Old Mar 10, 2014 | 10:38 PM
Jadedbird's Avatar
its true. but its nice to know its there when you wanna push the issue
Old Mar 12, 2014 | 04:04 PM
sublime1996525's Avatar
That's true but more hp is always just a few mods away
