Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
***Help!*** 4L60e vs 4L65es***Help!***
Old Feb 23, 2014 | 11:13 PM
Patro46's Avatar
Default ***Help!*** 4L60e vs 4L65es***Help!***
Will a torque converter from a 4L65es work in a 4L60e?
Old Feb 24, 2014 | 08:26 PM
sschoeffler's Avatar
Yes, the only difference between a 4L60e and a 4L65e is a 5 pinion planetary gear set. Other than that they are identical in nearly every way.
Old Mar 22, 2024 | 08:03 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Well you said it sat for a long time, could be the clutch degraded or mositure a number of possibilities. Trans stilling a long period is never really a good idea unless they are prepped for it .
__________________
