Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
HELP, Need expert advise!
Old May 10, 2014 | 08:17 AM
brianw401's Avatar
Default HELP, Need expert advise!
Clutch experts please chime in. I just installed a new master cylinder in my c5z06 & now the pedal won't go down. It won't budge! The install was easy & went really smooth until I tried to pump the pedal to bleed it. I even unhooked it from the pedal to ensure the pedal wasn't the problem & it moves freely when not connected to the cylinder. The fluid levels are normal & the slave was replaced when the clutch was done. The only reason I replaced the master was it had a leaky seal. Any advise will be greatly appreciated. Thanks!
Old May 12, 2014 | 02:33 AM
Murder_C5's Avatar
Try unhooking the line & pushing to see if some sort of blockage occurred. Just a thought.
Old May 13, 2014 | 06:24 AM
GravelSurfer83's Avatar
Same thing happened to a buddy. He didn't have the hyd line fully engaged. The clip still fit but it wasn't fully connected inside. If you force the pedal you will snap the plastic holding it.
Old May 13, 2014 | 07:03 AM
99ATHENASS's Avatar
Listen to the guy above me. He is correct.
Old May 15, 2014 | 02:44 PM
SNLPerformance's Avatar
I agree with the above the connection is not being made for the pedal to be hard, hope that helps.
