Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Need help with tune
Old May 21, 2016 | 04:02 PM
CuL8tR's Avatar
Default Need help with tune
Just installed a stage 1 procharger and a speed density tune from PCMofnc on an 02 c5 base A4. They tuned it before through email. I have the 2 bar map sensor but it won't start and there closed till Monday. If I install the Maf tune it will run decent but then surge and seems like it goes rich, but Im guessing that's normal because of the 2 bar map sensor. I also get a code for too much air flow which seems normal to me with the blower. Anyone have any info on where I should start. It's basically a stock motor and manifolds with the blower, 60lbs injectors , boost a pump and ported throttle body. Thanks
Old May 21, 2016 | 07:53 PM
brobinson216's Avatar
Did you email them? If so one of them will get back with you.
Old Jun 5, 2016 | 07:20 PM
CuL8tR's Avatar
Just an update. Got the tune figured out. They forgot to add the injector data in the tune. Once fixed it started right up.
