Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Misfire questions
Old Jul 22, 2016 | 08:15 PM
Twixer01's Avatar
Default Misfire questions
Hi all, long time reader of the forums.
So I recently changed the plugs and wires on my 2003 c5. Pretty much all stock. Since then, I have been getting a random misfire. It isn't pulling up a code/check engine light which is a bit surprising because it's pretty obvious.
I have called a few shops around (Sarasota, Fl) to see if they could diagnose which cylinder it is but most don't have the right gear. I am still calling around, but been busy.
It doesn't start misfiring until it's warmed up. I removed and inspected all the plugs and reseated the wires (except #7) but those all seemed ok. Since it started doing after I did the initial plug and wire change I have to assume it's a bad plug, wire or I messed up something while changing them?
Anyone have any suggestions? I figure the fact that it doesn't start until it's warmed up might be an indication of the issue?
Thanks,
adaM
Old Aug 2, 2016 | 09:19 AM
Twixer01's Avatar
So, I took my car to the local GM/Chevy dealership to have the service department have a look. The said the #3 cylinder is misfiring. They said they swapped plugs, wires and ignition coil but the #3 kept misfiring.
They think it could be the lifter or cam bleeding down. They said the #3 cylinder does 170PSI.
Any thoughts from the forum? Since replacing the the plug, wire, coil is pretty cheap, I still plan on doing that (just in case). I would love to try replacing other stuff before I look into replacing lifters or a cam. =/
