Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 manual shifting problems
Old Apr 24, 2017 | 09:41 AM
michaelsteyer's Avatar
Default C5 manual shifting problems
I bought this car at 49,500 miles the problem started at 51,000 miles. It started with grinding going into 5th when shifting normally. When I shift slowly and pause at the indents and take about 2 seconds between shifts i can get it to slip in witout grinding. A couple hundred miles later it started to do the same in 4th and the the same with third after another couple hundred more miles. I changed the trans fluid and put in Mobile 1 synth and i tried to do a shifter adjustment with no change in either case. So far 1st, 2nd, 6th and reverse work fine.
