Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
HEADERS - Dyno Proven Advice??
Old Aug 14, 2004 | 07:58 PM
vettenuts's Avatar
SW are also stainless front to back. As far as I have read, only the Kooks uses the mild steel mid section. I like the Kooks, but the installation is more than I am up for as I have to do this alone so I am looking for a simpler installation.
I would like to preserve the four O2 sensors to keep the car closer to stock and prevent some of the issues that have occurred to a lot of LG owners. Although I must admit I haven't seen any complaints on the LG's throwing codes in several months so maybe they fixed the issue.
Old Aug 16, 2004 | 08:37 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
The codes were not from having 2 or 4 o2's it was from the o2's not staying hot enough. Thats all squared away, and they work fine.
Old Aug 16, 2004 | 02:18 PM
Brody's Avatar
Lou told me that we would throw codes until we got in there with edit or hptuners??
Old Aug 18, 2004 | 11:56 AM
J-Rod's Avatar
In front, there were switching issues (o2s getting cold). The rear o2s because they are farther back have a higher wattage rating, and stay hot, so when you use Lou's adapter harness and put rear o2s on the front, you then generate no codes. The Rear o2s get a sim which won't generate a code. If you tune the car, you simply remove the code for the rear o2. That is most likely what is being referred to.
All headers will require tuning for proper performance.
Old Aug 18, 2004 | 11:58 AM
Brody's Avatar
Is that adapter harness a special order item/extra cost?
Old Aug 18, 2004 | 12:10 PM
J-Rod's Avatar
My understanding is it is included at no cost. o2 sims are an item you do pay for. But you can make one yourself for $.50
Old Aug 18, 2004 | 12:49 PM
Brody's Avatar
Thanks J-Rod!
You're one of the most knowledgeable vette guys around. It's great that you still waste your time with our questions. Thanks
