Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Nitrous wiring for c5
Old Aug 4, 2024 | 12:37 PM
Boogsawaste's Avatar
Default Nitrous wiring for c5
Can someone check my wiring for me? I’m running a NX wet kit with a NOS wot/rpm switch (15982), and Lingenfelter LNC-2000 for timing retard. I suppose I could use the stage 1 output for both the LNC and 86 on the relay but it has 2 stages so maybe just run it separately like I have depicted? This will be on a 2000 vette. Everything look ok? This is just for the nitrous arming and safety. I will also add a purge, pressure controlled heater, and possibly a remote bottle opener but I’ll make up new circuits for those. I know I don’t have all the inputs/outputs on the correct sides of the parts but still easy even to read lol. Thanks for any help or opinions.
Old Aug 4, 2024 | 02:48 PM
Tommy42088's Avatar
Go on lingenfeltor web page and they give you step by step instructions for many different options. When I used to be on Nitrous that how I installed mine and there instructions worked perfectly. I had lnc2000, winmax, and progressive controller all installed.
Old Aug 4, 2024 | 06:36 PM
I forgot about that site. I will give it a browse and hopefully they have something similar to my setup that I can extrapolate on. Thanks for the reminder and if anyone else has any input I’d appreciate it!
Edit: I checked the ligenfelter site and I have the lcn 2000 hooked up right but I’m not 100% on the rest of it like the window switch. I usually don’t like mixing different manufacturers but I had a lot laying around so might as well put it to use!
Old Aug 15, 2024 | 11:20 AM
All works as it should EXCEPT this one part: the second stage on the NOS switch is a ground, not a 12v+ like the stage one. I jumped off of the stage 1 and it works.
