which torque converter to run?
TCs run around $700 or so. Lots of the forum vendors sell TCs.
BTW, since your going to have to drop your exhaust, rear sway bars, rear diff, and tranny to install the TC, consider upgrading your gears to at least a 3.42. An upgraded TC deserves an upgraded rear diff gear ratio!!
I am going to do a heads and cam package on my vette, and my tranny was built to handle the power of that, but with the shift kit, and the tolerances of the transmission, the car has developed a real harsh one to two shift under normal driving. To get a real strong strong tranny to handle nitrous or boost, they usually will design it to eliminate the computer control on the one to two shift, to avoid blowing the servos. The computer monitors too many things and will try to tell the tranny to slip too much, or turn up the line preasure too much which can blow the tranny or burn the clutches. So on some heavy builds be aware that the 1 to 2 shift will be harsh no matter how much you tune the computer. Most builds can compensate for the shift of the tranny for real nice for putting around, and real hard at wide open throttle, but it depends on how much you build your car. If you start getting up to the 500 hp mark, then a solid tranny build will be necessary. I burnt out my clutches with a stock motor from just running it hard.
I hope some of this blabbering on helps you make up your mind.
