Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
et street wheel options?
Old Aug 17, 2004 | 09:06 AM
mattz06's Avatar
Default et street wheel options?
I do alot of street racing and cannot hook on bfg 315/30-18 drag radials with nearly 600 rwhp on the spray. I am wanting to switch to et streets.
I know that a 16" is supposed to be better than a 17" tire/wheel for hooking, but is it that big a difference?
I am thinking about getting another front set of z06 17" rims to run on the rear with 26x 11.5-17 et streets.
but if it's THAT big a difference maybe just firebird 16" rims with 16" et streets?
Old Aug 18, 2004 | 01:12 AM
hodgeee's Avatar
You poor bastard, I'm so sorry you have to deal with that pesky 600hp! I hate you in the kindest of ways! Man that car must be fast as hell!
Old Aug 18, 2004 | 05:48 AM
Vogonuts98z's Avatar
Not to hijack the thread, but this actually applies to the thread...I have heard that if you wanted to use a 16" F body rim, that you might have to do some grinding for them to fit properly. If not, that would be cool, because I have a set of 16" firebird rims with a brand new set of BFG DR's on them.
Old Aug 18, 2004 | 06:05 AM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Firebird or Camaro wheels will fit but will require extensive grinding on the knuckle and ball joint.17 inch ET Streets don't hook like a 16 incher.I bought a set of CCW drag wheels with tires for my car.They're pricey but I drive around on them most of the time.Unfortunately we don't have alot of options with these cars as far as drag wheels go.
Old Aug 18, 2004 | 07:12 AM
hodgeee's Avatar
If I am not mistaken don't they offer a 345/35/18 drag, that being over an inch wider per wheel may make a difference, don't know if that will fit, but I remember someone selling their car that had those size tires on the rear with custom made HRE rims. I just couldn't imagine any car with 600 hp hooking very well at all except for pure drag tires. If I am not mistaken also, I believe that they have true drag radials in 17" sizes, by Mickey Thompson. Just use some Z06 front rims on the back of the car. I think just gaining an inch in sidewall will make a huge difference, a lot more flexability!
Old Sep 20, 2004 | 02:08 PM
2MuchRiceMakesMeSick's Avatar
The difference is the sidewall. With a 16 inch wheel you are allowed to have more sidewall.
Old Sep 22, 2004 | 07:03 PM
c5jim's Avatar
Default MT STREET-17"
Go for it. Just put my 17" MT ST on 435 + RWHP on my C5 and they will hold ! I know you don't spray out of the hole because I just took a 150+ NOS off mine. 17" will pull a Hell of a holeshot. They will fit fine on Z06 front rims. C5JIM
Old Sep 23, 2004 | 11:20 PM
Kap_99C5's Avatar
I have heard that regular size c5 wheels actually work better then the z06 because it gives you a little more in the way of sidewall, and so actually has a wider contact patch on the ground when launching...
Old Oct 5, 2004 | 09:01 AM
XTrooper's Avatar
Is anyone running into problems with stability, etc with radials on the front and ET Streets on the rear?
Old Oct 5, 2004 | 03:43 PM
Assassin's Avatar
you can get a set of 16" draglites made to fit... and then throw the et streets to them, but is there a reason not to go to et drags?(you dont have to worry about a driveshaft saftey loop or c-clip eliminators, lol......(though you will need the extended studs)
Old Oct 13, 2004 | 06:53 PM
fastbasser's Avatar
I am also wondering about the stability question. It is said you can't mix the two (bias and radial) .
Has anyone tried it?
