6 Inch Rods
And the reason they may be saying go w/ longer rods is b/c with a longer rod you have less stroke, which leads to more torque (typically). Thats about the only thing I could see their reasoning behind it, especially not knowing your plans for the car.
I dont see a problem in going w/ longer rods, as long as its setup properly, but w/o knowing your plans for the car, for now i'd say leave well enough alone, and not touch 'em. If your plans are to go w/ a boost or nitrous huffin engine later, then it may be "insurance" now to just do it while the top ends apart instead of later. But you may wanna upgrade the pistons also if going that route.
No, a shorter stroke crank gives you less stroke. Longer rods just means...well, the rods are longer.
To accomplish this you will need different pistons (with the wrist pin moved higher.) The gain? Not worth the trouble, IMO. Your peak piston velocity will be a little less, the piston will not side load the cylinder quite as much, and, most importantly, the piston will spend more time at and near top dead center. All this adds up to a very small gain in power for the $$$.
