Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Vette AC System Failure
Old Oct 1, 2004 | 12:10 AM
Will Clark's Avatar
Default Vette AC System Failure
So I notice that I can put it on floor, face, defrost, both, it doesn't matter. It will always come out of the defrost and floor vents.
1st - Whats the name of the thing controlling this, I thought it was the blendor motor but I can't find info about it anywhere.
2nd - Would my diagnosis be correct?
Car in sig.
Old Oct 1, 2004 | 06:21 PM
Lost's Avatar
Common problem.Loss of vacuum between rear of intake and BCM will cause the symptons described. Most often the problem is the plastic vacuum lines have degraded or split. Requires removing the battery and the inner fender panel cover.
