Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Evans LS1 Water Pump GP
Old Nov 1, 2004 | 01:28 PM
Nasty N8's Avatar
Default Evans LS1 Water Pump GP
We are doing it again the Evans Water pump GP. We need to get 10 opumps ordered to get these prices guys.
Evans Cooling Systems Incs highflow LS1-6 water pump. The billet coolant pump and pulley flows over 20% more than stock and changes the cooling pattern for a more even cooling. The pump increases cooling efficiency in modified LS1 Corvettes, Camano’s and LS1 based motors. Evans has changed the design of the OEM pump casting and includes a billet pulley hub and heavy duty 3/4" shat bearing assembly. It also includes a 3.8" OD 8 vane scrolled impeller to reduce parasitic horsepower loss at high RPM. A new serpentine belt is required.
pics
Evans complete new water pump with billet pulley $469.95 for Corvettes
Evans complete new water pump with billet pulley $469.95 for F-Bodies
New Evans complete new water pump with billet pulley $469.95 for Trucks
Brand new casting no core retail $469.99 GP $395.00 NO core required
Used casting remachined retail $399.99 GP $340.00 +$125 core charge
Add $125 for ceramic thermal coating-for extra heat dissipation and a little bling
Evans super flow 160* T-Stat $49.95 reqiered with purchase stock does not flow enough
Goodyear serpentine belt $49.95
New Evans high flow aluminum fabricated radiators for the C5 Corvette available in different core configures. Drop the temps of that big HP motor retail $519.99 GP $435.00 6 orders
Evans NPG coolant $22.50 a gallon
Evans NPG+ coolant $22.50 a gallon
Also Evans new NPG R race coolant in stock $19.50 a gallon
Any questions please call.
Thanks Nate
