Patriot Performance Products?
Dave
Thank you guys I really appreciate your feed back. See, I own a 99 Z28 and right after I bought it a year and a half ago I started to buy equipment for it. I bought the HOT cam kit with the 2001 ZO6 springs, (soon after I got better springs due to the max valve lift i wanted),1.85 stainless steel roller rockers, TIT valve spring retainers,chrome molly push rods, double roller timing chain, blue printed and ported oil pump, 373 gears, K&N filter and LS1 lid and all the gaskets and new crank bolt. I did the old ram air trick under the air filter box and the throtle body coolant by pass. Also the MAF resistor and the Corsa Cat back. Deep inside I always wanted to own a Vette, but I did not know what to do since I was already on my way to fix the Z28 up. I do not know what happened, I don't know if I was starting to go through my middle life crisis at 44 years of age...but all of the sudden I went to Dallas Texas last summer and brought me back a low mileage 2001 C5. Now I am in a dilema, because I already bought some stuff and as I kept reading through different forums, there is so much new stuff that keeps coming up for the LS1 that I do not know if I should fix the Z as I planned before or sell it and work on the vette. That is the reason why I am seeking feed back and advise. What do you guys think???
