please help identify my mods..pics in side
plus, there is a picture of the sensor that looks to me to be unplugged... it's located on the passanger side back near the firewall... any help would be greatly appreciated.
isn't there something that i can clip onto that unplugged 02 sensor (click on the 4th pic in my first post) that can bypass it and stop throwing codes?
You have cats. Just plug the 02 sensor back in or go buy new ones if you still are throwing codes. If you ever run off road pipe meaning no cats you have an 0b2 car which means instead of the normal sniff test they plug a computer up to yours to see if you’re throwing any emissions codes. If you are you fail. The sims cover up the codes and trick the computer into thinking everything is fine, in a sort of easy way to explain it.
By all means figureing out the cam is damn near impossible unless you pull it and mic it or cam doc it.
