Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
M6 Shift skip mod for $2
Old Feb 22, 2005 | 03:29 PM
98LSVETTE's Avatar
Default M6 Shift skip mod for $2
This mod will allow you to disable the annoying computer assisted gear selection for those of us with the M6 tranny. The basic idea of this mod is to remove the lockout solenoid from the system, and prevent the ECM from setting a trouble code by fooling it into thinking the solenoid is still connected.
When the CAGS solenoid is connected, the ECM sees the effective resistance of the coil in the relay. When the connector is unplugged, the ECM will see an open circuit or infinite resistance, and sets a trouble code to warn of CAGS solenoid failure. To prevent this code, a 2.2K ohm ½ watt resistor is placed in the end of the wiring harness after it is unplugged from the solenoid. Now the ECM will see the same coil resistance as it did when the wiring harness was connected to the CAGS solenoid. No codes will be set, and the CAGS lockout solenoid will cease to function. Now, you will no longer be prevented from shifting into second gear from first during conservative driving.
Note: This mod will not prevent the Skip Shift light from illuminating on the console. After completion of the mod, the light will be meaningless, and you can ignore it.
Materials required:
2200 or 2.2K ohm ½ watt (Radio Shack), Electrical Tape, Tie Wrap
Here you can see the CAGS wiring harness that connects to the solenoid on the top of the T56 transmission. This solenoid is the farthest forward of the three connectors on the tranny.
Disconnect the harness from the solenoid. Be certain you are disconnecting the correct plug.
2.2 ohm ½ watt resistor inserted into the female portion of the CAGS wiring harness.
Use black tape or some sort of weather proofing to seal the resistor and female CAGS plug from the elements.
Tie wrap the sealed CAGS connector up out of the way so that it will not hang freely.
Old Feb 22, 2005 | 04:05 PM
30th TA 0219's Avatar
thanks for the tip, and welcome to 1993!
Old Feb 22, 2005 | 10:30 PM
Robert56's Avatar
Cags defeat how-to
Old Feb 23, 2005 | 01:49 AM
2MuchRiceMakesMeSick's Avatar
yeah...1993 was a good year
