Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
2000 Corvette issues?
Old Feb 27, 2005 | 10:01 PM
Formulized94's Avatar
Default 2000 Corvette issues?
are there any known issues with the 2000 corvette? I am looking into a 6 speed convertible. I also have a mild 6.0 being built for my ta, should the 6.0 be reserved for the corvette?
Old Mar 4, 2005 | 09:17 PM
Blktie8's Avatar
I love the 2000
I have no oil issues and the only issue is they are not fast enough but neither is an 01 -04
If you want to spin it up get new Katech rod bolts and while your in there get the katech oil pump and timing chain .
If the 6.0 is an ls2 aluminum go for it .
If it is iron Put it in a truck save your money for the ls2 4.0 stroke 402 or c5r block .
Have fun
I only have 14 k on the 2000 vert and 0 problems
except my addiction for mods
Do it once and correct the first time ,I should listen to my own drummer
good luck have fun
John blktie8
Either is good foundation
Old Mar 8, 2005 | 07:16 PM
pdd's Avatar
pdd
mine gets lots of oil in the intake
Old Mar 12, 2005 | 03:16 PM
zo6vetteman2003's Avatar
Yes, if it is C.I. throw it in the truck.
Old Mar 13, 2005 | 09:41 PM
lar66bb's Avatar
Default 2000
Only the normal ones: column lock, gas quage, rear end leak. which is common
to all. other than that a great car.
