Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Baer Eradispeed +1 rotors
Old Mar 14, 2005 | 07:26 PM
smask04C5's Avatar
Default Baer Eradispeed +1 rotors
Wil they fit on an 04 C5 with Z51 suspension?
Old Mar 16, 2005 | 11:10 AM
Dean-o's Avatar
The plus 1 Eradispeeds are larger in diameter and require relocating the caliper and should work with the OEM rims and Z51 suspension on a C5. They will not work with a Z51 suspension on a C6 however. I'm not sure why. You can check with Baer if you need confirmation.
Old Mar 16, 2005 | 03:34 PM
smask04C5's Avatar
I recently read a disclaimer that they would fit a C5 with minor modification. 14 inch rotors will fit inside rear wheels, but unsure as to the minor modification. Thanks for the reply dean-o
