Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What makes a valve seize in the guide? (on multiple occasions)
Old Dec 11, 2001 | 06:30 PM
BALD RUNFLATS's Avatar
Default Re: What makes a valve seize in the guide? (on multiple occasions)
my guess would be a bad guide, *allways replace the guide if a valve bent,,, are these heads ported? If so,were bigger valves and new seats installed? check valve height and replace the valve spring. Id replace the lifter too <img src="gr_images/icons/wink.gif" border="0">
Old Dec 11, 2001 | 10:58 PM
racer7088's Avatar
Incorrect guide clearance also possibly. What guides do you have?
Old Dec 12, 2001 | 12:37 AM
Visceral's Avatar
Default What makes a valve seize in the guide? (on multiple occasions)
That was the first time.
Now while at MTI, it happened a second time.
MTI folks say the oil is getting to the top of the head...
This is getting old.
In the below picture, I had 4 sets of head bolts. My car now has created 2 more sets in the last month, and its getting REALLY OLD.
Old Dec 12, 2001 | 10:49 AM
Joe Kizzire's Avatar
Resident Grump
Incorrect rocker arm geometry causing side loading of the valve stem.
