Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
alighnment
Old Jan 9, 2002 | 01:26 AM
BLKC5's Avatar
Default alighnment
Taking the Vette in for some FREE service, and I was was wondering about some good alighnment settings. I autox, roadrace and take long trips. like Denver to Vegas. I was thinking about a ZO6 spec alighnment this time. Anything better? <img src="graemlins/corvette.gif" border="0" alt="[Corvette]" />
Old Jan 10, 2002 | 12:29 AM
Godspeed's Avatar
Default Re: alighnment
Hi there, here are some good alignment specs.
Z06 Specs
Front
Camber -0.5
Caster 6.0
Toe 0.0
Rear
Camber -0.10
Toe +0.10
DRM Recommended Alignment Specs
Front
LF -1.5 deg camber RF -1.5 deg camber
LF 6-7 deg caster RF 6-7 deg caster
Front toe setting 0 or 1/16 inch toe in
You can set the front camber in the range of -1.5 to -2.0.
The -2.0 setting might be better for you.
Rear
Camber settings LR -1.0 RR -1.0
Toe setting LR 1/16 toe in RR 1/16 toe in
Make sure you run toe in. You can run a little less toe than this if you want.
-Jeremy
[ January 09, 2002: Message edited by: Godspeed ]</p>
Old Jan 10, 2002 | 02:42 AM
BLKC5's Avatar
Thanks for your time! <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Jan 10, 2002 | 02:49 AM
BlownC5's Avatar
Great info! Posts like this make these Boards great! <img src="gr_grin.gif" border="0">
<img src="graemlins/z06.gif" border="0" alt="[Z06 Corvette]" />
Old Jan 10, 2002 | 11:44 AM
66ImpalaLT1's Avatar
Should I use the Z06 specs with stock tires?
Eric
