C5-Z06 Suspension swap
Thanks for any input.
I'll be doing this soon and documenting part#'s and install procedure.
The Z06 has a bigger front sway bar then all others, while the rear Z06 sway bar is the same for all '01-02 Z51 suspension equipt C5's (regardless if it's a coupe, hardtop, or vert).
The Z06 front transverse spring is the same for all '01-02 Z51 suspension equipt C5's (regardless if it's a coupe, hardtop, or vert), while the rear Z06 transverse spring is stiffer then all others.
As for the shock......go with Bilstien Sports.
New: - (4)Bilstien Sport shocks $280 + shipping
New: - Z06 Sway bars $270 + shipping
New: - Z06 springs $800 + shipping
Keep an eye out for fellow forum members selling their used Z06 suspension part and you can save a bundle......that's what i did.
FYI: I did the "Z06" suspension conversion from the base suspension (see sig below) and it was a 100% all around improvement.
<strong>97C5ENVY, looks like we agree on just about everything then <img src="gr_stretch.gif" border="0">
How hard was it swapping the springs? The rear looked easy, but I've not seen the front just yet.</strong><hr></blockquote>
Actually they the whole process (sway bars, shocks , springs and lowering) was really easy. However i ended up doing mine one upgrade at a time (first shocks, then sway bars, then springs & lowering). But if done all at once you'll save alot of time.......mainly from not having to raise and lower the car each time, and not having to remove and install certain pieces that have to come off.
If you like some specific help tips for installation of any or all of the suspension upgrade pieces feel free to email me at e_lynch@stonemedia.com
