Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
H&C install?
Old Apr 23, 2002 | 05:11 PM
F360's Avatar
Default H&C install?
I will be installing stage 2 H&C package during the next 2 weeks, I would like to know the parts required? Any advice will be appreciated.
<img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
<small>[ April 23, 2002, 05:12 PM: Message edited by: F360 ]</small>
Old Apr 24, 2002 | 03:36 PM
jmX's Avatar
jmX
Default Re: H&C install?
You need headbolts and head gaskets for a 99 and up car. If you have a 98 you'll need a few more...water pump gaskets and possibly timing cover gasket?
There's more info here:
http://ls1.fbody.com
Old Apr 24, 2002 | 04:47 PM
F360's Avatar
Thanks for the information.
I wonder if the cam installation for C5 is similar to F-body, or there are different steps for C5. Do I need the 3 jaw pulley puller? Do I need to get new bolt for the crank pulley?
My car is 99, is it possible to use 2002 head gasket?
Thanks
Old Apr 24, 2002 | 06:23 PM
jmX's Avatar
jmX
You will need a 3 jaw puller. You will need a new crank bolt. I don't beleive you can use the new style head gaskets on the older heads.
You'll need to remove the steering rack, but once thats out of the way you'll be set and it'll be just like an fbody.
