Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Differences between 98 & 99 C5
Old Jul 15, 2002 | 09:51 PM
boos2's Avatar
Default Differences between 98 & 99 C5
What are they other than the HUD option? Thanks
Mike
Old Jul 15, 2002 | 10:10 PM
99RamAirTA's Avatar
Default Re: Differences between 98 & 99 C5
98 Ls1's have bigger fuel injectors then a 99. I beleive the 98's were 28# compared to 26# for the 99. Also, the bolt pattern for the valve covers is different, and the coil packs were mounted directly on the valve covers in 98. I beleive 99 was the first year of the hard top model which eventually became the Z06. Thats about all I can think of right now, hope that helps
Old Jul 16, 2002 | 03:12 PM
Red98C5's Avatar
When I order my 98 (June 97) you could not order Active Handling, and my ABS unit is in the rear rather then the front. The PCM is different than the 99 and there are quite a few "subtle" changes elsewhere.
