Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What's the weight differences between Vette models?
Old Feb 14, 2003 | 02:57 PM
WILWAXU's Avatar
Default What's the weight differences between Vette models?
I've been having thoughts of a ZO6.. but have a chance to pick a very clean one owner convertible.
What's the weight differences between Coupe, Hardtop & Convertible?
Old Feb 14, 2003 | 03:35 PM
1BAD-SS's Avatar
Default Re: What's the weight differences between Vette models?
I would go to www.chevrolet.com and look under specs for the year that you are interested in. If its not there try www.caranddriver.com Between the those two sites you should find what you are looking for. However, I think that if you have a chance to get a Z06 and don't that you will regret it. Personally I'll be wainting for the C6 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 15, 2003 | 01:50 AM
LS1LT1's Avatar
The coupe (targa) and convertible are very close in weight (within 10 pounds of each (used to be one pound different) other depending on options, only 1 pound apart when the similarly equipment.
The hardtop LS1s ('99 and '00) weighed around 70 pounds less with the Z06 slightly lighter than that even.
Old Feb 16, 2003 | 04:04 PM
Ling_650vette's Avatar
fixed roof coupes (Z06) style cars weigh in around 3100-3200lbs. Coupes and Converts are around the 3300-3400 range. try www.corvetteactioncenter.com for specifics
Old Feb 16, 2003 | 08:31 PM
C5Vert's Avatar
I may not be exact, but these are very close.
Coupe and Vert around 3214 (I've seen different numbers, but all within 10 lbs). Z06 around 3110.
Old Feb 16, 2003 | 08:52 PM
66ImpalaLT1's Avatar
Just to note, I weighed my coupe at 3090lbs with very little gas. This was with nitto drag radials on the back (17x8.5 97-99 style wheels) and stock runflats on the front.
Thats before I swapped out the stock manifolds and cats for FLP's.
Eric
Old Feb 16, 2003 | 09:57 PM
MarkP's Avatar
Check the Corvette ACtion Center's Model Center:
http://www.CorvetteActionCenter.com/specs/
