Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Need a 3" muffer with inlet and outlet on same side...
Old Feb 28, 2003 | 04:58 PM
Chicago Z06's Avatar
Default Re: Need a 3" muffer with inlet and outlet on same side...
Call mufflex.. pretty much the only option if they even offer that style of muffler.. not sure if they offer that setup or not.. they do offer 3" dual setups though... unless your running over 407 CID full race setup its really not worth the expense or weight increase?? but you know your setup.. no info on that hope it helps...
Wes
Old Feb 28, 2003 | 07:33 PM
Ling_650vette's Avatar
Mufflex should have something. They use either Spintech or Flowmaster mufflers (altho i think they'll put just about anything up there if you've got the $$$)
Now, are you wanting a single 3" inlet, and 3" outlet? cause if so, WHY????? the dual setup is the best bet, flows better, and sounds better. "Choking" it off w/ a single wouldnt be a good idea, imo.
<small>[ February 28, 2003, 07:37 PM: Message edited by: Ling_650vette ]</small>
Old Mar 1, 2003 | 12:15 AM
Phil99vette's Avatar
7 Second Club
Default Need a 3" muffer with inlet and outlet on same side...
I am trying to build a 3" exhaust for my C5 and ran into some problems finding a muffler. I need a 3" inlet and outlet on the same side.
Phillip
