Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
HUD question
Old Jul 13, 2005 | 01:05 AM
Third Gear's Avatar
Default HUD question
Would it be possible to put a head's up display in a vette that didn't originally come with it? I'm looking at very clean 2000 FRC, it's perfect excecpt that it doesn't have HUD. How much of a PITA would this be? Thanks.
Old Jul 13, 2005 | 06:47 AM
PA Z06's Avatar
I have seen them for sale, and in theory anything is possible if you want it bad enough, I dont know how hard or if anyone has tried
Old Jul 13, 2005 | 07:28 AM
Assassin's Avatar
it has been done before, go check corvetteforums , theres a post on how to do it and all the parts needed!!!
Old Jul 13, 2005 | 01:58 PM
Third Gear's Avatar
Thanks a lot. CorvetteForum was my second bet... I was already on here so I figure I'd throw it out, and see if anyone knew.
Old Jul 13, 2005 | 07:30 PM
StealthZ06's Avatar
First of all you must have a car with the HUD enabled cluster. The 97's and 98's didn't have it, you should be fine since you have an 00. The hardest thing about the install is taking the dash apart, and cutting it. The parts you will need are: the HUD projector, dash bezel, switch, and 11 Pin from the switch to cluster. All in all these parts are around $300. There is a detailed installation guide over at the corvette forum. Typically it takes 4-6 hours for the install. The corvette's with factory HUD have a specially tinted windshield (~$800), however the HUD displays just fine on the standard windshield. Good luck, you will love the HUD.
