Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
DTE diff. brace... installed...
Old Aug 7, 2005 | 03:39 PM
Assassin's Avatar
Default DTE diff. brace... installed...
I wont get into how much of a pain doing an in-car install this was, but man does this thing act as a traction device or something?, after the install I went up the road to do a burnout, and I revved it up pretty high so I wouldnt just launch, and popped the clutch at about 4k and the wheels just barked loud once and the car friggin took off, I kept in it and it was pulling HARD off the line w/ no tire spin, WOW, does anybody else have a dte and notice anything like this?, maybe my conditions were perfect and tires were hot enough(20min. @ 65mph) but I swear I can feel a big difference, seems like the power goes right to the ground when I'm on the gas now...
Old Aug 8, 2005 | 04:30 PM
Assassin's Avatar
nofukin body here has a dte brace????
Old Aug 8, 2005 | 08:12 PM
Sigforty's Avatar
The in-car install is that bad? I have been thinking of trying it on my car.
Old Aug 8, 2005 | 08:49 PM
Assassin's Avatar
you can do it but there's alot of drive by brail going on w/ upper bolts, follow the directions but first run all the bolts through where they go on the brace cause the paint gets in the holes and its a biatch to be messing with after its bolted on, also at least take off the muffler pipes...
Old Aug 9, 2005 | 01:45 PM
CrazyChris's Avatar
Yes the install is a bitch with the diff and subframe still attached. Even adjusting it with the jam nuts tight is a PIA.
I replaced a broken output shaft and installed the DTE brace at the same time. No difference in traction for me. I run ET Streets 90% of the time and they hooked the same after as before. A radial tire never hooks up, before or after the brace install. I don't see how it could provide additional traction. Glad it drives better for you though.
