Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
LS7 clutch swap
Old Sep 30, 2005 | 10:25 PM
Jstyle's Avatar
Default LS7 clutch swap
I am doing a LS7 clutch swap in my C5. My main question is when I put these parts in is this going to fix the grinding I get when I am trying to shift gears? I do know if there is a throw out bearing in these parts? If not will the ls1 bearing work?
Old Sep 30, 2005 | 10:42 PM
Jstyle's Avatar
Basically what I am asking is the throw out bearing in the pic I have attached?
Old Oct 1, 2005 | 06:59 AM
Assassin's Avatar
your grinding is caused by worn synchro's, I hear the z06 m12 ones are the way to go..., looks like the bearing right next to the flywheel, you should also get a mcleod adjustable master and I'm not sure if the lines in your car will require the drill mod or not, cant remember if they changed on newer ones...
Old Oct 3, 2005 | 11:31 AM
marlowchris's Avatar
The throuwout bearing is attached to the end of the slave. it sits on the spring, and yes it is in the pic. A bad throwout bearing will rattle and roar and will not cause grinding during shifting. That would either be the slave not fully engaging or the transmission. Do a search, there is mixed opinions on the McLeod adjustable and the drill mod. I would get a Z06 master and not do the drill mod.
Old Oct 5, 2005 | 02:50 PM
Robert56's Avatar
I agree, totally.
Robert
Old Oct 5, 2005 | 04:35 PM
Bombguy99z28's Avatar
Make sure you bleed it really well. If your fluid looked real bad and the pedal feel was crappy, it possibly could be your clutch, but I'd say in most cases its the tranny.
Old Oct 5, 2005 | 04:50 PM
Dragonsi's Avatar
if u don't have cash for a new tranny, i'd go with some synchromesh and lucas transmission additive, should fix a bit of grinding
Old Oct 7, 2005 | 11:32 AM
eb02z06's Avatar
Do you have the part #'s for each individual piece-Fred Beans does not ship to Canada?
