Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
what is the difference between these air bridges
Old Oct 9, 2005 | 07:06 PM
chandlerc5's Avatar
Default what is the difference between these air bridges
an 01 and up aftermarket air bridge, and a 97-00 bridge. i have a 99 c5 but a bridge for an 01. it is connected to an slp bellow and BBK. will it fit over the radiator shroud without any problems?
Old Oct 10, 2005 | 05:35 AM
XTrooper's Avatar
Yes, it should fit over the radiator shroud without a problem. The difference is that the early-type are usually drilled for the IAT sensor. On the 2001+ cars, the IAT sensor is incorporated into the MAF sensor, so the hole isn't necessary and consequently isn't present on the later-type air bridges.
Old Oct 16, 2005 | 09:34 AM
muncie21's Avatar
Maf size also changed from 01 to 02+, requiring larger diameter coupling
Old Oct 18, 2005 | 01:50 AM
chandlerc5's Avatar
i guess they just cant leave anything alone can they?
Old Oct 22, 2005 | 09:15 AM
z06ufgrad2002's Avatar
I think they call it progress or technology or something like that.
