Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Baer Brake Upgrades
Old Oct 11, 2005 | 11:39 AM
tbyrne's Avatar
Default Baer Brake Upgrades
EradiSpeed Rotors
EradiSpeed represents Baer's premium line of performance rotors. Featuring the dynamic appearance of cross-drilled, slotted and zinc-coated surfaces, EradiSpeedTM units are also purpose-cast with quality iron materials for performance far beyond the factory units they replace. Furthermore, EradiSpeed´s curve-vaned design also provides greater airflow and heat dissipation.
EradiSpeedTM rotors feature:
Faster thermal recovery
Increased heat absorption
Increased friction and lower wear
Cross-drilled, slotted, and zinc-washed
Limited lifetime warranty against warping
The EradiSpeed product line is offered in the following four categories:
EradiSpeed 1-piece direct OE replacement rotors
EradiSpeed-Plus 2-piece (hat & disc) OE replacement rotors
EradiSpeed-Plus-One 1-piece increased diameter replacement rotors
EradiSpeed-Plus-Two 2-piece (hat & disc) increased diameter replacement rotors
EradiSpeed-Plus-One indicates a set of rotors a size larger that still work with the OEM calipers. The result is increased performance by virtue of the augmented leverage of the larger rotor. Baer provides all the hardware necessary to move the location of the OEM calipers outward. EradiSpeed-Plus-One rotors may work with OEM wheels but usually require larger wheels, see application notes.
EradiSpeed-Plus-TwoTM features the same elements as the Plus-One Systems in a lighter weight two-piece design utilizing NAS stainless hardware and installs WITHOUT BLEEDING!
Features:
INCREASED DIAMETER rotor upgrade systems employing OEM calipers
Increased rotor diameter = greater leverage and improved brake torque
Rotors are LARGER than the OE units they replace and are designed for use with larger than stock wheels.
Includes specialized caliper hardware to properly accommodate installation
Are always directional with curved vanes.
Feature crossdrilled, slotted and zinc coated surfaces
The Hawk HPS pads are a very good upgrade to go along with these rotors.
Looking for a little more than just a rotor upgrade? Baer has a number of big brake packages available -
Brake Systems Value is more than price. Take a close look at a Baer System, compare it with competitors and determine for yourself which delivers real value. Our systems feature the finest calipers in the world. All employ proper road going dust and weather seals, making them appropriate for use on streets and highways. Our Systems are not just a kit; they include everything you will need. If your application requires a master cylinder, hose, or special fitting it´s included. Systems requiring hubs not only arrive with the races and studs installed, but are also assembled with TimkenTM bearings and packed with RedlineŽ Synthetic grease. When deciding which system fits your needs, examine technology, quality, performance, and integrity. We think you´ll agree Baer has no competition for the best value.
To best fit your needs, Baer has established two product lines.
Claw Systems are built one way.
All Claw Systems have fully optioned rotors. The nature of the Claw line allows distributors to stock product easier. This means that a Claw System can be purchased and shipped with minimal delay.
Select Systems are built to order.
If you can imagine it, we can build it. Starting from a 2-piston PBR PGC caliper and ending with a 6-piston race caliper we´ve got what you need. Pick the color of your caliper, hat, or maybe just get it polished.
Common options include:
Two-piece rotor upgrades where available
Rotor options include: plain, cross-drilling, slotting, and zinc-plated surfaces
Caliper color (all) or polished (PBR only)
Hat color or polished
Upgraded pads
Alternate rotor dimensions
Upgraded studs
We carry the complete Baer line-up and offer VERY competitive prices! They are up to 15% off of Baer's regular retail and we will also pick up the tab for shipping orders in the 48 states.
More info and pricing can be seen on our website. Many part numbers are in stock for immediate shipment!
