Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
408 pulley alignment issues
Old Nov 30, 2005 | 11:26 PM
kindaslo's Avatar
Default 408 pulley alignment issues
Anyone else ever have alignment issues when putting an iron block 408 in your c5?
Mine is a 97 c5 with a lunati billet stroker kit. Seems as though the balancer needs to get further onto the crank so the pulleys will line up. I am using all arp bolts, and am going to compare the arp crank bolt to a stock one to see if it is too long and not pulling the balancer on all the way.
My only other thought is maybe I need a different balancer, I tried the truck balancer and no way (hits steering rack)
Any suggestions?
Old Nov 30, 2005 | 11:32 PM
kindaslo's Avatar
Nevermind I'm retarded and didn't notice the bolt backed out.....
Old Dec 1, 2005 | 09:05 AM
CrazyChris's Avatar
There is always little stuff like that when doing a motor swap. Glad it was an easy fix for you this time.
Old Dec 1, 2005 | 02:39 PM
VINCE's Avatar
Shorty Director
Any suggestions?
You need a C5 balancer. You cant use any other type of balancer or it will not work.
Old Jan 18, 2006 | 08:38 AM
kindaslo's Avatar
If anyone else ever has this problem, i had to pin the crank and use an ati dampner to stop it. Bolt just would not stay in.
Old Jan 18, 2006 | 09:23 AM
SideStep's Avatar
Just for peace of mind I always pin the crank now...
