Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
code??????
Old Jan 20, 2006 | 05:54 PM
jcori3's Avatar
Default code??????
a friend has a 2000 vette all stock with a grannatelli air intake system. Everything has been fine untill today when a code came up and he had it scanned and they told him it was a po410 code. any advice would help, thanks
Old Jan 20, 2006 | 06:17 PM
Stu's Avatar
Stu
Secondary AIR system code.
Check the AIR pump hoses and make sure the pump is working. BTW: He can scan his own codes thru the DIC.
Old Jan 20, 2006 | 09:58 PM
ram-it's Avatar
He will need to replace the check valve on the passenger side in the back. You can pick one up for about $20-25 at most auto parts stores.
Old Jan 20, 2006 | 10:00 PM
ram-it's Avatar
Also do a google search for Corvette DIC Codes. There is a site that tells you how to scan and clear codes plus a complete list of codes.
