Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Front Wheel Hub?
Old Mar 27, 2006 | 10:01 PM
BlackHawk02's Avatar
Default Front Wheel Hub?
Has anyone replaced one? If so how difficult was it and can I use any ball joint separator or do I need to use the specific tool mentioned in the manual?
2001 Corvette Convertable
Last edited by BlackHawk02; Mar 27, 2006 at 10:03 PM. Reason: Needed to include more info
Old Mar 28, 2006 | 10:53 PM
terry s's Avatar
If you use a wedge style (pickle fork) to separate the ball joint you will ruin the rubber boot. Check with your local auto store & see if they loan tools. I know Auto Zone does. I was in Auto Zone today and they had a picture of all the tools they loan on the counter. I believe O-Reilly does also. I think you pay for the tool (in case you keep it) and they give your money back when you return the tool. They should have a ball joint separator that will not damage the boot.
I have not done one but if you have the factory manual it should guide you. If you don't have one let me know. I have an 02 manual I could fax the pages to you. I imagine it would be the same as your 01.
Old Apr 6, 2006 | 10:29 PM
usd2sing's Avatar
http://www.jakelatham.com/C5/misc/C5...el_Bearing.doc
i used this write up. first one took 3hrs 1 of which was spent driving around looking for a 55tqx.
other side took 1.5hrs.
