Camshaft LSA
what does the + mean? for example some cams are 224/228 114+1 LSA.
Anyone can correct me as I am semi-guessing.
Ideally, if you have a good performance cam, and heads, you may want to go 112LSA on a natural aspired application. On a FI application, you want 114-116LSA
HTH
Goose
HTH
Goose
The +1 means the intake center line (ICL) is ground 1 degree advance. If the lsa is 112 and it has 1 degree of advance the ICL would be 111...
The more time both valves stay open (overlap) the greater the lope or shake... not a specific lsa.
As far as power goes.... Street driven 346 LS1s "like" an intake valve closing (IVC) between 43-46 degrees @ .050 and an IVO and EVC at equal distances from TDC... Anything later turns into a high reving qtr mile application. Anything sooner tends to kill off top end power but gives strong pulling in the low to mid RPM range... Also, having an early IVC builds more cylinder pressure and makes for better low-rpm driving...
Soooo, if I wanted a good NA cam for my Z06, then would your cam be the one to get?
