ls2 & ls6 heads
what cfm does ls1, ls6, and ls2 heads flow?
I think thats the only difference,....what you mentioned. "think"
They are both the 243 castings. So they flow the same...I think the only real difference is the valve setup which allows a bit higher lift rate, but I not 100%.
Get a set of LS6 heads with some work on them and you will be fine!
