Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
16" wheels for the back?
Old Apr 29, 2006 | 12:17 PM
bluestreak98's Avatar
Default 16" wheels for the back?
What will fit? I want to put some 16" Et Streets/Drags on the back of my car. What do u guys use? Any f-body wheels?
Old Apr 29, 2006 | 01:37 PM
NOSjohn's Avatar
Restricted User
I'm 99% sure C4 wheels will fit, I've seen a few C5's using those for drag wheels.
Old Apr 30, 2006 | 05:42 PM
TwinTurboZo6's Avatar
I have 16" 's all around thou its the ccw drag pack
Pete
Old May 3, 2006 | 11:18 AM
ROJO99's Avatar
I believe that unless you have CCW's, 16" rims will require some grinding of a stiffening rib on the control arms and the flattening of a bearing cap or two.
My .02 here, may not be fact so check before you buy...
Old May 3, 2006 | 03:46 PM
REDGAR's Avatar
I have used the 5 spoke fbody wheel on 10.5 x 16 et streets. requires some grinding or pounding down the upper a arm on the rear.
Old May 3, 2006 | 09:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I recall seeing Butcher with C4 BBS wheels in back.
