Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
LS7 head question
Old Apr 30, 2006 | 07:21 PM
c5_ls1_6spd's Avatar
Default LS7 head question
why can't LS7 heads fit on a 346ci C5 shortblock?
Old Apr 30, 2006 | 07:33 PM
BlueSix's Avatar
valves are too big for the bore.
Old Apr 30, 2006 | 07:40 PM
what if i were to bore out my C5 346ci shortblock?
will LS7 heads fit on a LS2 shortblock?
Old Apr 30, 2006 | 08:15 PM
ftlfirefighter's Avatar
Heads reqiure a 4.125 (4 1/8) bore, there's not enough meat in the sleaves of an LS2 for that much of an over bore. You'll have to the block resleaved.
Old May 1, 2006 | 01:02 AM
what about a 408? will LS7 heads fit on it?
Old May 1, 2006 | 08:33 AM
If you mean 408 as in 4.030 x 4.000 then no. A 4.125 x 3.625 (stock stroke) = 387 cu/in. Thats the minimum bore size needed to clear the LS7's valves. Being that "overs-square" you could spin it well into the 7000s. Remember, HP = Tq x RPM / 5252. The more rpm the higher the hp.
I used to build and test gas turbine helo engines in the Marine Corps, a GE-T700 turbo shaft makes 430 ft/lb at 20,000 rpm which when you do the math equals: 1,637 Hp!
Old May 1, 2006 | 10:53 PM
DocT's Avatar
Oohrah Devildawg!!!
Old May 1, 2006 | 10:55 PM
Outfrigginstanding DocT! YUT!
Old May 2, 2006 | 01:03 AM
can you bore a 408 out to 4.125?
Old May 2, 2006 | 07:49 AM
That depends C5, is it an iron or aluminum block? What's the bore dimension now?
Old May 2, 2006 | 11:48 AM
right now im on the stock 346, but i would like to build an engine first, then pull out my old motor, drop the new one in and sell my old motor. im think of maybe a forged 408, 422 or 427 shortblock, with ETP LS7 heads or stock LS7 head and hardware up top. A nice sized cam (yet to be determined) and my goal is 550-600rwhp NA with a 7500rpm redline.
Old May 2, 2006 | 12:52 PM
AHH ok, now we're on the same page!! LOL Do what I'm doing, buy an LS7 crate motor for around $13,000, have the reluctor and cam sensors changed to work with your factory ecu and your set!! You're looking at $20-25k to duplicate what GM sells in a box read to go!
Old May 2, 2006 | 05:58 PM
that $13000k is really deterring me. i can get a procharger for 4k or turbo for 6k and a built 346ci motor for 4k and make much more power than NA. im still trying to conduct a cost-benefit analysis.
Old May 2, 2006 | 06:41 PM
I hear ya brother. Turbos for my car installed are 13K, so which would I rather have right?
