Intake Manifold for a 99
Does the Vette' LS1 mainfold have an EGR or is the EGR-less LS6 manifold a direct swap on to the vette without becoming part of the non-emissions crowd??? Not that I'm concerned with emissions but it's something that was on my mind.
Second, the LS2 manifold. I've heard this being talked about as very similar to a Fast manifold (after the casting for the LS2 has been smoothed at least). Is this a direct bolt on also to the LS1?? I know it's meant for a 90mm TB, but would the stock vette TB (whatever size it is) bolt up to the LS2 manifold??
Just doing some researching. Thanks everyone.
I'm sure one of the more experienced members will chime in on this and correct me if I'm wrong. I hope you get the answers you're looking for. Good luck!
The LS2 intake manifold sucks, regardless of it's larger diamater opening. Yes, the LS6 78mm is better then the stock LS2 90mm. There is dyno charts on this. See Katech.
