Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Need Help - Head/Cam
Old May 3, 2006 | 11:33 AM
2K-Z28's Avatar
Default Need Help - Head/Cam
Ok, I did my camaro two years ago and had problems matching head/cam. Please let me know what you have found to be the best set up for a head cam package. #'s as well (Just got my first Vette 00 M6!!)
Old May 3, 2006 | 01:28 PM
MICAH HERRON's Avatar
From: Johnsonville, SC; but orginally from GAINESVILLE, FL
Depends on what sort of cash flow you want to blow. I am thinking, if I had limitless amounts of cash, I would do a set of AFR heads and a G5X2 or 3 cam from LG.
Old May 3, 2006 | 02:06 PM
SideStep's Avatar
How drivability are you will to give up and do you have to pass a true sniffer emission test?
I like cams with no more than 53/4 degrees overlap @.006/050 and an IVC no later then 43 degrees(ish) @.050, but I drive my Vette a lot so manners are important to me. This will also get you strong pull from the red light without having to rev to the ceiling...
Old May 3, 2006 | 08:02 PM
2K-Z28's Avatar
I live in Nebraska no em. tests, with head, cam, exhaust, nitro, intake, fuel and tune. i do not want to spend more than 3500 - 4000
