What is the fastest vette on 6 speed ?
Their telephone is:
(888) 937-4411
A 67mm turbo can run, depending on manufacturer (top 3) and the housing sizes, around $1300 to $1700+. I haven't heard much feedback on these eBay turbos, so I'm not so sure I would use something like those...in case someone asks.
Maybe they said 44mm compressor exducer / 57mm turbine exducer?
Either way, they sound small, if you're looking at the goals you have in mind, you'll need to go bigger.
60-67 turbos.
67's will take you to about 1150 rwhp at 22 psi.. with a good setup on 116.
Maybe that would help. I know it will be hard to hit eights but if I do it just once Ill be happy. Then I will just run nines all day in the heat. The convertion the an auto is way too much money so I have no choice but to stick with the 6 speed.
Any clutch ideas ?
Any clutch ideas ?
Cartek VII. At this hp. level, you will not even get a weekend out of it.
Tilton Triple. $4,500-$5,200
Have your machine shop re-balance the assembly.
SFI Blanket or Trans shield a must have.
I'm also not positive a set of T-67's will fit in the existing location of the kit you have. You may want to call them and ask. Again, something in the 63mm-67mm range will get you to your goal easy...just a matter of keeping the drive line together.
Call, if you like, if you have more questions to address.
