Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
LS6 intake swap
Old May 15, 2006 | 12:39 AM
rob2269's Avatar
Default LS6 intake swap
Correct me if i'm wrong, but I am going to be swapping out my intake on my 2000 vette for an ls6 intake off a 01 SS. And i read that all c5's and 01 and up f-bodies have no egr setup. If this is true then it should be a direct swap.Is this correct?If not what will i need to do and what are all the parts that i will need for the swap.ALL the parts. Thanks...
Old May 15, 2006 | 05:32 AM
2MuchRiceMakesMeSick's Avatar
That is correct. C5 and 01+ f-bodys have no egr.
Old May 15, 2006 | 06:24 AM
homegrown TA's Avatar
ls1howto.com
Old May 16, 2006 | 06:37 AM
V-seriesTech's Avatar
You'll need to get the new coolant lines for the car. The lines that go from head to head... for the cooling system, will no longer work with the LS6 intake manifold. You need to get the two coolant caps, that go in the back of EACH head with their new O rings,....and then you need to get the jumper coolant line that goes or COnnects to each head. If you need the part numbers,...I'll research them.
J
